Cleaning the Controller Buttons
  1. Cleaning the Controller Buttons, Cleaning the Controller Buttons: step 1, image 1 of 2 Cleaning the Controller Buttons, Cleaning the Controller Buttons: step 1, image 2 of 2
    • Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
    • Remove the back panel from the controller.
  2. Cleaning the Controller Buttons: step 2, image 1 of 3 Cleaning the Controller Buttons: step 2, image 2 of 3 Cleaning the Controller Buttons: step 2, image 3 of 3
    • Remove the 3 screws (4.8 mm Phillips head) from the back of the white box.
    • Remove the back panel of the joystick box.
    • There are many small plastic components loose in this box; be careful not to lose these.
    • Separate the rubber pads and plastic buttons from the controller.
  3. Cleaning the Controller Buttons: step 3, image 1 of 2 Cleaning the Controller Buttons: step 3, image 2 of 2
    • Using a soft cleaning material, clean the plastic buttons.
    • Using a toothpick, clean the pole slot, shown at the right of the Q-Tip.
  4. Cleaning the Controller Buttons: step 4, image 1 of 2 Cleaning the Controller Buttons: step 4, image 2 of 2
    • Using a damp, soft cleaning material, clean the rubber button pads.
    • To ensure that no electrical damage occurs, ensure that you dry the pieces completely after cleaning them.
  5. Cleaning the Controller Buttons, Put it back together: step 5, image 1 of 1
    • Reinsert the buttons, ensuring that the rubber, cylindrical pieces protruding from the buttons are lined up with their corresponding circuits.
Follow these steps in reverse order to reassemble your device.
7 other people completed this guide.
Jason Gittler
135 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 60
All Time: 6,195
