Cleaning/Degreasing Heat Sink
  1. Cleaning/Degreasing Heat Sink, Cleaning Debris from Flywheel Screen: step 1, image 1 of 3 Cleaning/Degreasing Heat Sink, Cleaning Debris from Flywheel Screen: step 1, image 2 of 3 Cleaning/Degreasing Heat Sink, Cleaning Debris from Flywheel Screen: step 1, image 3 of 3
    • Ensure the engine is off and cooled down before starting this guide.
    • Using a 5/16" socket or wrench, remove the three bolts holding the plastic cover on to the engine.
    • Lift away the plastic cover. Note that the starter is attached to the cover and will come off with it.
  2. Cleaning/Degreasing Heat Sink: step 2, image 1 of 2 Cleaning/Degreasing Heat Sink: step 2, image 2 of 2
    • Using compressed air or a rag, clean debris from the flywheel.
  3. Cleaning/Degreasing Heat Sink, Cleaning/Degreasing Heat Sink: step 3, image 1 of 2 Cleaning/Degreasing Heat Sink, Cleaning/Degreasing Heat Sink: step 3, image 2 of 2
    • Using compressed air and a rag, clean the heat sink.
Aaron Correya
239 Reputation
2 Guides authored
Cal Poly, Team S25-G15, Maness Spring 2018 Member of Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 378
