ClickN Kids Tablet Camera Replacement
  1. ClickN Kids Tablet Camera Replacement, Camera: step 1, image 1 of 1
    • Start on the side with the camera
    • Insert a plastic opening tool into the space between the screen and the back side.
    • The screen side is black, the back side is colored
  2. ClickN Kids Tablet Camera Replacement: step 2, image 1 of 1
    • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
    • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
    • The corners can be tricky. Make sure to separate the pieces all the way around the tablet before attempting to open it.
  3. ClickN Kids Tablet Camera Replacement: step 3, image 1 of 1
    • Lift the detached screen from the camera side until you can see the inside of the tablet.
    • Don't open too fast, or you might damage the ribbons cables.
  4. ClickN Kids Tablet Camera Replacement: step 4, image 1 of 2 ClickN Kids Tablet Camera Replacement: step 4, image 2 of 2
    • Be careful not to damage any wires or ribbon cables during this step.
    • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
    • There is a black tab behind the long ribbon cable. Lift up the black tab.
    • For the ribbon cable in the back, pull the black tabs on the side out.
    • Detach the ribbon cables connecting the screen to the motherboard.
    • Remove any tape that is holding down the ribbon cables. Set it aside.
  5. ClickN Kids Tablet Camera Replacement: step 5, image 1 of 1
    • Pull off the tape that holds the ribbon cable to the battery.
  6. ClickN Kids Tablet Camera Replacement: step 6, image 1 of 2 ClickN Kids Tablet Camera Replacement: step 6, image 2 of 2
    • Be careful not to damage the wires or ribbon cables.
    • Pull out the two black ends of the base on the motherboard.
    • Slide out the camera’s ribbon cable once the ends are loosened.
  7. ClickN Kids Tablet Camera Replacement: step 7, image 1 of 3 ClickN Kids Tablet Camera Replacement: step 7, image 2 of 3 ClickN Kids Tablet Camera Replacement: step 7, image 3 of 3
    • Use a plastic opening tool to pry the camera out of its place.
Kevin Finney
562 Reputation
4 Guides authored
Baylor, Team 4-4, Williams Spring 2015 Member of Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 912
