Clothing Ribbon Button Replacement
  1. Clothing Ribbon Button Replacement, Clothing Ribbon Button Replacement: step 1, image 1 of 2 Clothing Ribbon Button Replacement, Clothing Ribbon Button Replacement: step 1, image 2 of 2
    • Examine the garment where your ribbon button came off. There should be a little pocket where the ribbon came out.
    • Stitch rip the seam around the little pocket until it is large enough to easily slide the ribbon in.
  2. Clothing Ribbon Button Replacement: step 2, image 1 of 2 Clothing Ribbon Button Replacement: step 2, image 2 of 2
    • Tuck one end of the ribbon into the pocket, inserting the ribbon past the missing seam.
    • If you are are using a ribbon that has an obvious front and back, insert the ribbon so that the back is facing out.
  3. Clothing Ribbon Button Replacement: step 3, image 1 of 3 Clothing Ribbon Button Replacement: step 3, image 2 of 3 Clothing Ribbon Button Replacement: step 3, image 3 of 3
    • Holding the ribbon in place, slide the garment into the sewing machine, aligning the presser foot with the place you want the button to sit.
    • Do not sew the pocket with the ribbon end in it closed.
    • Sew the ribbon in place.
  4. Clothing Ribbon Button Replacement: step 4, image 1 of 3 Clothing Ribbon Button Replacement: step 4, image 2 of 3 Clothing Ribbon Button Replacement: step 4, image 3 of 3
    • Backstitch to hold the stitches in place.
    • Lift the presser foot and remove the garment from the sewing machine.
    • Clip any threads.
  5. Clothing Ribbon Button Replacement: step 5, image 1 of 3 Clothing Ribbon Button Replacement: step 5, image 2 of 3 Clothing Ribbon Button Replacement: step 5, image 3 of 3
    • Thread the ribbon through the button coming up from behind, over the spoke in the middle, and back down through the second hole.
  6. Clothing Ribbon Button Replacement: step 6, image 1 of 3 Clothing Ribbon Button Replacement: step 6, image 2 of 3 Clothing Ribbon Button Replacement: step 6, image 3 of 3
    • Pull the ribbon taught.
    • The button should be facing with the backside out.
    • Fold the button and ribbon back over, so that the other side of the button is facing out.
    • Leave just enough ribbon to tuck into the little pocket. Clip all excess ribbon.
  7. Clothing Ribbon Button Replacement: step 7, image 1 of 2 Clothing Ribbon Button Replacement: step 7, image 2 of 2
    • Fold the free end of the ribbon, tucking it into the little pocket, in the same manner as the first.
    • Overlap the two ends of the ribbon so that they sit directly on top of one another.
    • Sew directly over the seam, closing the little pocket.
    • This seam should catch both ends of the ribbon between the two layers of the pocket.
  8. Clothing Ribbon Button Replacement: step 8, image 1 of 3 Clothing Ribbon Button Replacement: step 8, image 2 of 3 Clothing Ribbon Button Replacement: step 8, image 3 of 3
    • Backstitch to hold the seam in place.
    • Remove the garment from the sewing machine.
  9. Clothing Ribbon Button Replacement: step 9, image 1 of 2 Clothing Ribbon Button Replacement: step 9, image 2 of 2
    • Clip any threads.
    • Admire your handiwork.
Finish Line
Brittany McCrigler
90,511 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,790 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 37
All Time: 3,453
