Coby Kyros MID7012 Battery Replacement
  1. Coby Kyros MID7012 Battery Replacement, Battery: step 1, image 1 of 1
    • Wedge the metal spudger in between the faceplate and the body of the tablet.
  2. Coby Kyros MID7012 Battery Replacement: step 2, image 1 of 2 Coby Kyros MID7012 Battery Replacement: step 2, image 2 of 2
    • Carefully pry the faceplate away from the body of the tablet.
  3. Coby Kyros MID7012 Battery Replacement: step 3, image 1 of 1
    • Carefully lift the screen and set it face down on a soft surface to not scratch it.
  4. Coby Kyros MID7012 Battery Replacement: step 4, image 1 of 3 Coby Kyros MID7012 Battery Replacement: step 4, image 2 of 3 Coby Kyros MID7012 Battery Replacement: step 4, image 3 of 3
    • Carefully pry the battery away from the body of the tablet using the plastic spudger.
  5. Coby Kyros MID7012 Battery Replacement: step 5, image 1 of 2 Coby Kyros MID7012 Battery Replacement: step 5, image 2 of 2
    • Using a soldering iron heat up the location where the wire meets the motherboard. Remove the red wire first, then the black wire.
    • Clip the grey wire about an inch from the ribbon using a sharp object.
    • Here are some tips on how to Solder.
3 other people completed this guide.
Daniel Ulrich
494 Reputation
3 Guides authored
IUPUI, Team 3-4, Harley Fall 2016 Member of IUPUI, Team 3-4, Harley Fall 2016
IUPUI-HARLEY-F16S3G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 1,282
