Coil Zipper Slider Replacement
  1. Coil Zipper Slider Replacement, Gather materials: step 1, image 1 of 3 Coil Zipper Slider Replacement, Gather materials: step 1, image 2 of 3 Coil Zipper Slider Replacement, Gather materials: step 1, image 3 of 3
    • Gather tools and the two pieces required for a coil slider replacement:
    • A replacement slider that is the right size and style
    • Reference the Zipper Identification guide to confirm the appropriate replacement piece.
    • A coil top stop in the correct size
    • Coil top stops look like a small metal claw with a flat back and three prongs (one on one side and two on the other).
  2. Coil Zipper Slider Replacement, Locate the top stop: step 2, image 1 of 3 Coil Zipper Slider Replacement, Locate the top stop: step 2, image 2 of 3 Coil Zipper Slider Replacement, Locate the top stop: step 2, image 3 of 3
    • Unzip the zipper.
    • Locate the top stop at the top of the zipper on the side with the slider.
    • The top stop is a piece of plastic or metal that keeps the slider from coming off the top of the zipper.
    • Peel back any fabric that is covering the top stop.
    • Wear safety glasses to protect from projectile pieces.
    • Use end nippers or flush cutters to remove the top stop.
    • To avoid cutting the zipper tape, position the nippers to cut off only the very edge of the stop, then peel away the rest of the stop from the zipper tape.
    • Use a lighter to singe frayed or damaged zipper tape.
    • Slide the damaged zipper slider up and off the zipper tape.
    • Discard the zipper slider responsibly.
    • Making sure the new slider is oriented correctly, slide it onto the zipper tape.
    • Patagonia Repair Tech Tip: Maneuver the slider as if parallel parking a car. Start at an angle, back it onto the zipper tape, and then straighten out. This step can take practice, patience, and a little muscle!
    • Once the slider is on the zipper, test zipping up the jacket to make sure it's the right slider type and that the issue is fixed.
    • Place the top stop on the flat, tape side of the zipper, aligning the double-prong side of the stop to face the jacket and the single-prong side to face the zipper teeth.
    • Slide the single-prong beneath the first or second tooth at the top of the zipper tape.
    • Push the double-prongs through the zipper tape so they emerge on the opposite side, on the inside of the coil.
    • Use pliers to bend the prongs of the stop inward, clamping them around the zipper coil. The prongs will grab into the coil, securing it in place.
    • Check that the new stop effectively prevents the new slider from coming off the zipper.
Finish Line
20 other people completed this guide.
Brittany McCrigler
89,739 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,417 Guides authored
11 Comments
Where do I get the zipper stop????
Jason Heimink - Reply
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
bbehrhorst - Reply
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
kasten39828 - Reply
AWESOME! Thanks for the pointers - I’m ready for tomorrow’s powder day!!!!
Jenny - Reply
Great now how ! thank’s :)
Robert Fyfe - Reply
Past 24 Hours: 13
Past 7 Days: 145
Past 30 Days: 585
All Time: 105,099
