ColecoVision Controller Port Replacement
  1. ColecoVision Controller Port Replacement, Controller Port: step 1, image 1 of 1
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
  2. ColecoVision Controller Port Replacement: step 2, image 1 of 2 ColecoVision Controller Port Replacement: step 2, image 2 of 2
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
  3. ColecoVision Controller Port Replacement: step 3, image 1 of 2 ColecoVision Controller Port Replacement: step 3, image 2 of 2
    • Remove the two 15mm screws holding the casing in place using the Phillips #1 screwdriver.
    • Remove the casing and put it to the side.
  4. ColecoVision Controller Port Replacement: step 4, image 1 of 2 ColecoVision Controller Port Replacement: step 4, image 2 of 2
    • Remove the two 15mm screws on the motherboard with a Phillips #1 screwdriver.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
  5. ColecoVision Controller Port Replacement: step 5, image 1 of 3 ColecoVision Controller Port Replacement: step 5, image 2 of 3 ColecoVision Controller Port Replacement: step 5, image 3 of 3
    • Flip the motherboard over and locate the two controller ports.
    • Using a soldering iron, desolder the controller ports.
    • Refer to this soldering technique guide for reference.
    • After waiting for controller ports to cool down, flip motherboard back over and carefully lift controller ports to remove.
Bobby
380 Reputation
2 Guides authored
UW Tacoma, Team S1-G2, Rose Fall 2018 Member of UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 1,127
