ColecoVision Motherboard Replacement
  1. ColecoVision Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Start by laying the console face down.
    • Remove the eight 15mm Phillips #1 screws from the bottom of the device.
  2. ColecoVision Motherboard Replacement: step 2, image 1 of 2 ColecoVision Motherboard Replacement: step 2, image 2 of 2
    • Flip the console back over.
    • Lift the front panel off. I would reccomended using a metal spudger along the rim of the top to safely remove it and set it aside.
  3. ColecoVision Motherboard Replacement: step 3, image 1 of 2 ColecoVision Motherboard Replacement: step 3, image 2 of 2
    • Remove the two 15mm Phillips #1 screws holding the casing in place.
    • Carefully lift the casing from the motherboard.
  4. ColecoVision Motherboard Replacement: step 4, image 1 of 1
    • Remove the center Phillips #1 screw near the cartridge slot.
    • Remove the second Phillips #1 screw near the RAM chips.
    • Carefully lift and remove the motherboard.
Krystalina
121 Reputation
1 Guide authored
UW Tacoma, Team S1-G2, Rose Fall 2018 Member of UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 26
All Time: 2,023
