Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement
  1. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Battery: step 1, image 1 of 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Battery: step 1, image 2 of 2
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: step 2, image 1 of 1
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: step 3, image 1 of 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: step 3, image 2 of 2
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: step 4, image 1 of 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: step 4, image 2 of 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: step 4, image 3 of 3
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
  5. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Main Power Board: step 5, image 1 of 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Main Power Board: step 5, image 2 of 2
    • Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
    • Remove the plastic barrier.
  6. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: step 6, image 1 of 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: step 6, image 2 of 2
    • Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing.
  7. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: step 7, image 1 of 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: step 7, image 2 of 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: step 7, image 3 of 3
    • Gently grab the main board by the exposed PCB.
    • Pull the main board straight out of the housing.
Mathew Merrick
169 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 595
