ComNet Ericsson Panther 600P Buttons Replacement
  1. ComNet Ericsson Panther 600P Buttons Replacement, Locate the release button.: step 1, image 1 of 3 ComNet Ericsson Panther 600P Buttons Replacement, Locate the release button.: step 1, image 2 of 3 ComNet Ericsson Panther 600P Buttons Replacement, Locate the release button.: step 1, image 3 of 3
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Buttons Replacement, Antenna: step 2, image 1 of 1
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Buttons Replacement, Dials: step 3, image 1 of 1
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Buttons Replacement, Exterior Case: step 4, image 1 of 3 ComNet Ericsson Panther 600P Buttons Replacement, Exterior Case: step 4, image 2 of 3 ComNet Ericsson Panther 600P Buttons Replacement, Exterior Case: step 4, image 3 of 3
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  5. ComNet Ericsson Panther 600P Buttons Replacement, Remove Buttons: step 5, image 1 of 2 ComNet Ericsson Panther 600P Buttons Replacement, Remove Buttons: step 5, image 2 of 2
    • Grip the corner of the button pad and gently peal it away from the faceplate.
    • Clean off any sticky residue and/or replace the buttons.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 235
