Introduction
If your device has received water damage or experienced a similarly devastating event, the motherboard may have become damaged or even destroyed.
This guide will take you through the necessary steps to access and replace the motherboard.
Look for the release button on the back of the radio.
Press the button and pull down on the battery at the same time. The battery will come free.
Using a T15 Torx screwdriver, unscrew the two screws.
Using a plastic opening tool, pry the internal case from the external case.
Remove the rubber O-rings from the antenna jack, volume switch, and channel switch.
Once the rubber O-rings have been removed, use small needle nose pliers to unscrew the nuts on the antenna jack, volume switch, and channel switch.
Using any convenient hand-placement, pull the motherboard away from the case.
The antenna jack, volume dial, and channel dial are attached to the motherboard. Be sure to pull the motherboard downward so they clear their respective slots in the case.
Lift the motherboard completely free of the case.
