Compaq Evo N1000v LED Cover Replacement
  1. Compaq Evo N1000v LED Cover Replacement, LED Cover: step 1, image 1 of 1
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v LED Cover Replacement: step 2, image 1 of 1
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v LED Cover Replacement: step 3, image 1 of 1
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Compaq Evo N1000v LED Cover Replacement: step 4, image 1 of 1
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Compaq Evo N1000v LED Cover Replacement: step 5, image 1 of 1
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v LED Cover Replacement: step 6, image 1 of 1
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v LED Cover Replacement: step 7, image 1 of 1
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v LED Cover Replacement: step 8, image 1 of 2 Compaq Evo N1000v LED Cover Replacement: step 8, image 2 of 2
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
kim
77 Reputation
3 Guides authored
Cal Poly, Team 29-74, Johann Spring 2010 Member of Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 16
All Time: 2,904
