Compaq Presario CQ60-211DX Display Assembly Replacement
  1. Compaq Presario CQ60-211DX Display Assembly Replacement, Display Assembly: step 1, image 1 of 1
    • Start by making sure the CQ60 is powered down and that the disk drive is empty.
    • Flip the device over and remove the battery.
  2. Compaq Presario CQ60-211DX Display Assembly Replacement: step 2, image 1 of 2 Compaq Presario CQ60-211DX Display Assembly Replacement: step 2, image 2 of 2
    • Remove the rubber screw covers next to each of the two screen hinges using a metal spudger.
    • Unscrew the screws underneath the rubber cover using the blank Phillips-head screwdriver.
  3. Compaq Presario CQ60-211DX Display Assembly Replacement: step 3, image 1 of 2 Compaq Presario CQ60-211DX Display Assembly Replacement: step 3, image 2 of 2
    • Use the metal spudger to gently pry the plastic faceplate off the rest of the display.
  4. Compaq Presario CQ60-211DX Display Assembly Replacement: step 4, image 1 of 1
    • Unscrew the two screws in the top corners to separate the frame holding the assembly from the plastic of the lid.
  5. Compaq Presario CQ60-211DX Display Assembly Replacement: step 5, image 1 of 1
    • Disconnect the assembly from the chip located between the hinges by pulling the wires to the right.
  6. Compaq Presario CQ60-211DX Display Assembly Replacement: step 6, image 1 of 1
    • Pull the frame forward, and then unscrew the three screws on each side.
  7. Compaq Presario CQ60-211DX Display Assembly Replacement: step 7, image 1 of 1
    • Disconnect the ribbon cable on the back of the display by peeling back the tape and then pulling down on the cable.
2 Comments
My laptop model Compaq predario cq61 h
Rashid 007 - Reply
Computer on but display light of computer is running
Rashid 007 - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,269
