Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement
  1. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement, Hard Drive: step 1, image 1 of 1
    • First you will need to turn the laptop upside down.
  2. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: step 2, image 1 of 1
    • Remove the battery by pushing the switch to the left and removing the battery from its slot.
  3. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: step 3, image 1 of 1
    • Unscrew the three 3mm screws on the compartment underneath the battery.
  4. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: step 4, image 1 of 1
    • Use a Phillips screwdriver to remove the two 3mm screws on the lowest compartment.
  5. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: step 5, image 1 of 1
    • Use a Metal Spudger remove the panel. Underneath is where the hard drive is connected .
  6. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: step 6, image 1 of 1
    • This is where you detach your old hard drive and replace with the new component.
Breana Thibodeaux
760 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 349
