Compaq Presario v2000 RAM Replacement
  1. Compaq Presario v2000 RAM Replacement, Removing the RAM cover: step 1, image 1 of 2 Compaq Presario v2000 RAM Replacement, Removing the RAM cover: step 1, image 2 of 2
    • Loosen the 2 Phillips screws with RAM icons above them. Don’t worry if the screws won’t come out, as they’re attached to the door.
    • Lift the RAM door up and away.
  2. Compaq Presario v2000 RAM Replacement, Removing the existing RAM: step 2, image 1 of 3 Compaq Presario v2000 RAM Replacement, Removing the existing RAM: step 2, image 2 of 3 Compaq Presario v2000 RAM Replacement, Removing the existing RAM: step 2, image 3 of 3
    • There are two metal clips holding both RAM modules in place.
    • To unclip them, push them both outwards from the RAM stick with your fingers until it pops out and sticks up at an angle.
    • Pull the stick of RAM out.
    • Repeat the last 3 steps for the bottom RAM stick.
  3. Compaq Presario v2000 RAM Replacement, Installing the new RAM: step 3, image 1 of 2 Compaq Presario v2000 RAM Replacement, Installing the new RAM: step 3, image 2 of 2
    • Start at the bottom slot. Insert the new RAM at the same angle the previous RAM popped out at.
    • Push the RAM in until a click is heard.
    • Repeat the last 2 steps for the top slot.
  4. Compaq Presario v2000 RAM Replacement, Reinstalling the RAM cover: step 4, image 1 of 1
    • Repeat the first part of this guide to reinstall the RAM door.
If you encounter problems after installing new RAM, redo this guide, or follow a RAM troubleshooting guide.
Viscous
381 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 279
