Computer King Muffin Kinder 7 Screen Replacement
  1. Computer King Muffin Kinder 7 Screen Replacement, Screen: step 1, image 1 of 2 Computer King Muffin Kinder 7 Screen Replacement, Screen: step 1, image 2 of 2
    • Use the plastic opening tool help push out the microSD card from the microSD slot.
  2. Computer King Muffin Kinder 7 Screen Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to unclip the plastic front from the plastic back. Use the MicroSD slot to initially start the unclipping.
  3. Computer King Muffin Kinder 7 Screen Replacement: step 3, image 1 of 2 Computer King Muffin Kinder 7 Screen Replacement: step 3, image 2 of 2
    • Unscrew the nine 3.0 mm Phillips #00 screws.
  4. Computer King Muffin Kinder 7 Screen Replacement: step 4, image 1 of 1
    • The battery is glued onto the black plastic. Use the plastic opening tool to pry the battery from the black plastic
  5. Computer King Muffin Kinder 7 Screen Replacement: step 5, image 1 of 2 Computer King Muffin Kinder 7 Screen Replacement: step 5, image 2 of 2
    • There will be a black strip connected to the screen.
    • Use the pointy end of the spudger to unstick the black strip that is glued onto the screen.
  6. Computer King Muffin Kinder 7 Screen Replacement: step 6, image 1 of 3 Computer King Muffin Kinder 7 Screen Replacement: step 6, image 2 of 3 Computer King Muffin Kinder 7 Screen Replacement: step 6, image 3 of 3
    • You will need to remove 2 ribbon cables, one that is connected to the touch screen (by the battery) and one that is connected to the yellow plastic (by the speaker).
    • Use the flat end of the spudger to lift the black panel covering the ribbon cables.
  7. Computer King Muffin Kinder 7 Screen Replacement: step 7, image 1 of 1
    • Pull the two ribbon cables out so that they are no longer connected to the logic board.
  8. Computer King Muffin Kinder 7 Screen Replacement: step 8, image 1 of 1
    • Lift up the logic board and black plastic so that they are no longer covering the screen
    • Lift out the screen.
3 other people completed this guide.
Katherine
439 Reputation
3 Guides authored
UWT Liner: Group 2 Member of UWT Liner: Group 2
Community
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 570
