Connect Four Electronic Handheld Battery Compartment Replacement
  1. Connect Four Electronic Handheld Battery Compartment Replacement, Ensure the device is off.: step 1, image 1 of 1
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
  2. Connect Four Electronic Handheld Battery Compartment Replacement, Removing the battery casing.: step 2, image 1 of 2 Connect Four Electronic Handheld Battery Compartment Replacement, Removing the battery casing.: step 2, image 2 of 2
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
Kamaryn
225 Reputation
2 Guides authored
Baylor, Team 8-11, Williams Fall 2014 Member of Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 131
