Connecting Cables to the Motherboard
  1. Connecting Cables to the Motherboard, Connecting Cables to the Motherboard: step 1, image 1 of 2 Connecting Cables to the Motherboard, Connecting Cables to the Motherboard: step 1, image 2 of 2
    • Red- Optional ATX Connector
    • Orange- CPU Fan 1
    • Yellow- CPU Fan 2
    • Green- Main ATX Connectors
    • Light Blue- GPU
    • Blue- Panel Connectors
    • Pink- USB Connectors
    • Black- HD Audio
  2. Connecting Cables to the Motherboard, Optional ATX Connector: step 2, image 1 of 2 Connecting Cables to the Motherboard, Optional ATX Connector: step 2, image 2 of 2
    • Connect the two separate six-pin segments to six pins each on the 12-pin PCIE port.
  3. Connecting Cables to the Motherboard, CPU Fan 1: step 3, image 1 of 2 Connecting Cables to the Motherboard, CPU Fan 1: step 3, image 2 of 2
    • Connect the four pin segment to the four pin PCEI connector labeled "CPUFAN1."
  4. Connecting Cables to the Motherboard, CPU Fan 2: step 4, image 1 of 2 Connecting Cables to the Motherboard, CPU Fan 2: step 4, image 2 of 2
    • Connect the four pin segment to the four pin PCIE port labeled "CPUFAN2."
  5. Connecting Cables to the Motherboard, Main ATX Connector: step 5, image 1 of 2 Connecting Cables to the Motherboard, Main ATX Connector: step 5, image 2 of 2
    • Connect the 24 pin segment to the 24 pin PCIE port.
  6. Connecting Cables to the Motherboard, GPU: step 6, image 1 of 2 Connecting Cables to the Motherboard, GPU: step 6, image 2 of 2
    • Connect both of the separate eight pin segments to each of the eight pin PCIE ports on the graphics card.
  7. Connecting Cables to the Motherboard, Panel Connectors (Part 1): step 7, image 1 of 3 Connecting Cables to the Motherboard, Panel Connectors (Part 1): step 7, image 2 of 3 Connecting Cables to the Motherboard, Panel Connectors (Part 1): step 7, image 3 of 3
    • This PCIE port consists of eight pins, two rows of four.
    • Connect the "Power LED+" pin to the pin at the top right corner.
    • Connect the "Power LED-" segment to the pin next to the "Power LED+" segment in the top row.
    • Connect the "Power SW" segment to the two pins on the left side of the top row of pins.
  8. Connecting Cables to the Motherboard, Panel Connectors (Part 2): step 8, image 1 of 3 Connecting Cables to the Motherboard, Panel Connectors (Part 2): step 8, image 2 of 3 Connecting Cables to the Motherboard, Panel Connectors (Part 2): step 8, image 3 of 3
    • Connect the "HDD LED" segment to the two pins on the right side of the bottom row of pins.
    • Connect the "Reset SW" segment to the two pins on the left side of the bottom row of pins.
  9. Connecting Cables to the Motherboard, USB Connector: step 9, image 1 of 2 Connecting Cables to the Motherboard, USB Connector: step 9, image 2 of 2
    • Connect the nine pin segment to the nine pin PCIE port.
  10. Connecting Cables to the Motherboard, HD Audio: step 10, image 1 of 2 Connecting Cables to the Motherboard, HD Audio: step 10, image 2 of 2
To disconnect the cable ties, follow these directions in reverse order.
Grace Parsekian
211 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 56
Past 7 Days: 288
Past 30 Days: 1,246
All Time: 8,750
