Introduction
If the tripod mount has become stripped or the slots that the plastic mounts slide into become stripped, follow this guide on how to replace the mounting piece on your Contour Roam2.
Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
3 other people completed this guide.
2 Comments
I Need a battery, and check up.
Too many small screws for me, I am using it on a home defense air powered 50 cal with orange top. need to have a mount for that Ball Shooter. where can I get that project I live in the 831 AC
Or is their something used already working I got this needing a battery.
Help from a Person I can mail it
Thanks Dudley
