Contour Roam2 Waterproof Action Camera Record Slider Replacement
  1. Contour Roam2 Waterproof Action Camera Record Slider Replacement, Record Slider: step 1, image 1 of 1
    • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
    • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
  2. Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 2, image 1 of 2 Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 2, image 2 of 2
    • Rotate the metal ring counterclockwise until completely removed.
  3. Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 3, image 1 of 2 Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 3, image 2 of 2
    • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
  4. Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 4, image 1 of 3 Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 4, image 2 of 3 Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 4, image 3 of 3
    • Grab the camera on both sides and slide the outer shell forward until completely removed.
  5. Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 5, image 1 of 1
    • Lift the record slider out.
    • The record slider should come out easily no matter the position (forward or backward).
3 other people completed this guide.
Matthew Kofsky
548 Reputation
3 Guides authored
2 Comments
I have had this camera since I was 16 I am 21 now and there was something wrong with the slider I am glad I didn't get rid of it! Because of you it is fixed now!!!
Neiko Rivera (Specters) - Reply
Dose anyone know if there is an equivalent guide but for the “Contour +2”?
Christopher Hinrichs - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 944
