Convert a 360 (Fat) hard drive into a 360 S hard drive
  1. Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: step 1, image 1 of 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: step 1, image 2 of 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: step 1, image 3 of 3
    • Buy the drive at a cost you can afford to eat. This will void any warranties offered.
    • Remove the 3 screws from the bottom of the drive. Use a T6 Torx driver.
    • Remove the warranty seal and final screw. Use a T6 Torx driver.
  2. Convert a 360 (Fat) hard drive into a 360 S hard drive, Disassembly tip: step 2, image 1 of 1
    • If the drive is difficult to open and you are opening it to put the drive into a later Xbox 360 with no intention to preserve the enclosure, a screwdriver or pry tool can help.
    • If you are opening it to replace the drive inside for an original console, it is best to use a plastic pry tool instead. While a screwdriver "works" it will likely mar the enclosure.
  3. Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: step 3, image 1 of 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: step 3, image 2 of 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: step 3, image 3 of 3
    • If you are taking the enclosure apart for the bare drive, less caution is needed.
    • After removing the 4 bottom screws, remove the top cover. Remove the spring and locking tab before removing the drive cage.
    • Remove the drive cage from the drive enclosure. If the drive has never been opened, additonal force may be required.
  4. Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: step 4, image 1 of 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: step 4, image 2 of 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: step 4, image 3 of 3
    • Remove the four T10 Torx screws securing the hard drive.
    • After removing the screws, slide the top cover off and disconnect the drive.
    • Disconnect the hard drive and remove it from the enclosure.
  5. Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: step 5, image 1 of 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: step 5, image 2 of 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: step 5, image 3 of 3
    • If you do not use an official hard drive, you will need a WD hard drive, the Xbox hard drive sector security file and HDDhackr to partition the drive. Partition 2 must be restored manually.
    • After removing the drive from the old enclosure, open the new enclosure.
    • Put the drive in the enclosure label side up. Space may need to be added for 7mm drives.
    • Close the enclosure and install it in your console.
Finish Line
2 other people completed this guide.
Nick
89,825 Reputation
52 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,516 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 45
All Time: 3,594
