Coolpad 3300A Disassembly
  1. Coolpad 3300A Disassembly, Coolpad 3300A Disassembly: step 1, image 1 of 1
    • After removing the back of the phone (not pictured), remove the battery by lifting up from the bottom with your thumb. There will be a groove that allows you to remove the battery with your thumb.
  2. Coolpad 3300A Disassembly: step 2, image 1 of 3 Coolpad 3300A Disassembly: step 2, image 2 of 3 Coolpad 3300A Disassembly: step 2, image 3 of 3
    • Remove the four screws (30 mm long) which hold the front and back half of the unit together using a Phillips #000 screwdriver. There will be one screw in each corner.
  3. Coolpad 3300A Disassembly: step 3, image 1 of 3 Coolpad 3300A Disassembly: step 3, image 2 of 3 Coolpad 3300A Disassembly: step 3, image 3 of 3
    • Use a metal spudger to release all of the clips around the phone. These clips are used to hold the front and back panel on the phone together.
  4. Coolpad 3300A Disassembly: step 4, image 1 of 1
    • After the clips are released, carefully separate the back housing from the phone. Notice the sticker that appears in the red box holds the phone together, but can be peeled apart.
6 other people completed this guide.
Riley Casteel
395 Reputation
1 Guide authored
IUPUI, Team S1-G3, Harley Spring 2018 Member of IUPUI, Team S1-G3, Harley Spring 2018
IUPUI-HARLEY-S18S1G3
6 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 40
All Time: 1,399
