Coolpix S01 The power button won't turn on Replacement
  1. Coolpix S01 The power button won't turn on Replacement, The power button won't turn on: step 1, image 1 of 3 Coolpix S01 The power button won't turn on Replacement, The power button won't turn on: step 1, image 2 of 3 Coolpix S01 The power button won't turn on Replacement, The power button won't turn on: step 1, image 3 of 3
    • First make sure the camera is powered off.
    • Then take the Hex and PH000 bit to remove a 2mm screw on the left side of the camera.
    • Next, remove the 2mm screw on the right side of the camera.
  2. Coolpix S01 The power button won't turn on Replacement: step 2, image 1 of 3 Coolpix S01 The power button won't turn on Replacement: step 2, image 2 of 3 Coolpix S01 The power button won't turn on Replacement: step 2, image 3 of 3
    • Remove the 3mm screw from the bottom of the camera.
    • Once the 2mm and 3mm screws are removed, use the plastic opening tool to lift the sides of the camera and reveal the inside of the camera.
    • Be sure to remove the battery before continuing to repair.
  3. Coolpix S01 The power button won't turn on Replacement: step 3, image 1 of 3 Coolpix S01 The power button won't turn on Replacement: step 3, image 2 of 3 Coolpix S01 The power button won't turn on Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • After the battery is out, remove the gray button bar from the top of the camera with the smallest opening tool.
    • With the gray bar detached from the camera, turn it upside down. Using the hex and the J000 bit remove the two 1mm screws.
    • Take the needle nose tweezers to remove the power button.
  4. Coolpix S01 The power button won't turn on Replacement: step 4, image 1 of 1
    • You have successfully removed the power button and can replace it if needed.
Rieana Hayes
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 12
All Time: 782
