Coolpix S01 USB Cover Replacement
  1. Coolpix S01 USB Cover Replacement, USB Cover: step 1, image 1 of 3 Coolpix S01 USB Cover Replacement, USB Cover: step 1, image 2 of 3 Coolpix S01 USB Cover Replacement, USB Cover: step 1, image 3 of 3
    • First make sure the camera is powered off.
    • Use the Hex and PH000 tool to remove the 2 mm screw from the left side of the camera.
    • Next remove the 2 mm screw from the right side of the camera.
  2. Coolpix S01 USB Cover Replacement: step 2, image 1 of 3 Coolpix S01 USB Cover Replacement: step 2, image 2 of 3 Coolpix S01 USB Cover Replacement: step 2, image 3 of 3
    • Remove the 3mm screw from the bottom of the camera.
    • Once you have the 2mm and 3mm screws out, gently pull the sides up with the smallest plastic opening tool. This will reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 USB Cover Replacement: step 3, image 1 of 3 Coolpix S01 USB Cover Replacement: step 3, image 2 of 3 Coolpix S01 USB Cover Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • On the bottom of the camera, locate the USB port.
    • Gently slide the USB cover off of the camera with your fingers or tweezers.
    • You can replace the USB cover by purchasing one from a local electronics store or online at iFixit.com.
Fernando Ochoa
113 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 21
All Time: 622
