Core Assembly Removal
  1. Core Assembly Removal, Unfasten the screws: step 1, image 1 of 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the four 3.9 mm-long Torx T3 screws.
    • Depending on the condition of your driver, a Torx T4 bit may fit better.
    • Don't try to detach the back cover yet. It is still connected to the watch assembly.
  2. Core Assembly Removal, Open the watch: step 2, image 1 of 2 Core Assembly Removal, Open the watch: step 2, image 2 of 2
    • Be careful not to strain the sensor flex cable during this procedure.
    • Carefully lift the back cover by the watch crown edge and swing it open to an upward position.
  3. Core Assembly Removal, Disconnect the sensor cable: step 3, image 1 of 2 Core Assembly Removal, Disconnect the sensor cable: step 3, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable.
  4. Core Assembly Removal, Remove the back cover: step 4, image 1 of 1
    • Remove the back cover.
  5. Core Assembly Removal, Core Assembly Removal: step 5, image 1 of 1
    • Remove the three 3.7 mm-long Phillips #00 screws.
  6. Core Assembly Removal: step 6, image 1 of 3 Core Assembly Removal: step 6, image 2 of 3 Core Assembly Removal: step 6, image 3 of 3
    • Insert the flat end of a spudger into the notch at the upper end of the white plastic frame.
    • Use your spudger as a lever and pry up the core assembly.
    • Don't try to remove the core assembly all the way yet—it is still connected to the watch body.
  7. Core Assembly Removal: step 7, image 1 of 2 Core Assembly Removal: step 7, image 2 of 2
    • Carefully lift the loose edge of the core assembly up and swing it to a 100-degree angle.
    • Be careful not to strain the display and sensor flex cables during this procedure.
  8. Core Assembly Removal: step 8, image 1 of 2 Core Assembly Removal: step 8, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the core assembly.
  9. Core Assembly Removal: step 9, image 1 of 2 Core Assembly Removal: step 9, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the display flex cable from the core assembly.
  10. Core Assembly Removal: step 10, image 1 of 1
    • Remove the core assembly.
Repair didn’t go as planned? Check out our Answers community for help.
4 other people completed this guide.
Dominik Schnabelrauch
249,048 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,906 Guides authored
1 Guide Comment
Hello... in the event that you have submerged the smartwatch in salt water and it does not work, is there a solution?
luciano.alonso84@gmail.com - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 1,482
