Core Assembly Removal
  1. Core Assembly Removal, Turn off the watch: step 1, image 1 of 2 Core Assembly Removal, Turn off the watch: step 1, image 2 of 2
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Core Assembly Removal, Remove the rear screws: step 2, image 1 of 1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Core Assembly Removal, Separate the back cover from the housing: step 3, image 1 of 3 Core Assembly Removal, Separate the back cover from the housing: step 3, image 2 of 3 Core Assembly Removal, Separate the back cover from the housing: step 3, image 3 of 3
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Core Assembly Removal, Disconnect the sensor array: step 4, image 1 of 2 Core Assembly Removal, Disconnect the sensor array: step 4, image 2 of 2
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Core Assembly Removal, Remove the back cover: step 5, image 1 of 1
    • Remove the back cover.
  6. Core Assembly Removal, Disconnect the display and the mic array: step 6, image 1 of 3 Core Assembly Removal, Disconnect the display and the mic array: step 6, image 2 of 3 Core Assembly Removal, Disconnect the display and the mic array: step 6, image 3 of 3
    • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
  7. Core Assembly Removal, Undo the mic tape: step 7, image 1 of 3 Core Assembly Removal, Undo the mic tape: step 7, image 2 of 3 Core Assembly Removal, Undo the mic tape: step 7, image 3 of 3
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
  8. Core Assembly Removal, Lift the core assembly: step 8, image 1 of 2 Core Assembly Removal, Lift the core assembly: step 8, image 2 of 2
    • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
  9. Core Assembly Removal, Remove the core assembly: step 9, image 1 of 3 Core Assembly Removal, Remove the core assembly: step 9, image 2 of 3 Core Assembly Removal, Remove the core assembly: step 9, image 3 of 3
    • Lift out and remove the core assembly.
3 other people completed this guide.
Tobias Isakeit
129,649 Reputation
189 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 1,833
