Core Assembly Removal
  1. Core Assembly Removal, Power down your watch: step 1, image 1 of 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Core Assembly Removal, Unscrew the back cover: step 2, image 1 of 1
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
  3. Core Assembly Removal, Pry open the back cover: step 3, image 1 of 2 Core Assembly Removal, Pry open the back cover: step 3, image 2 of 2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. Core Assembly Removal, Disconnect the sensor flex cable: step 4, image 1 of 2 Core Assembly Removal, Disconnect the sensor flex cable: step 4, image 2 of 2
    • Lay the watch face down.
    • Carefully swing open the back cover by folding it to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. Core Assembly Removal, Remove the back cover: step 5, image 1 of 1
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
  6. Core Assembly Removal, Disconnect the hall sensor flex cable: step 6, image 1 of 2 Core Assembly Removal, Disconnect the hall sensor flex cable: step 6, image 2 of 2
    • Use the pointed end of a spudger to disconnect the hall sensor flex cable.
  7. Core Assembly Removal, Disconnect the display flex cable: step 7, image 1 of 2 Core Assembly Removal, Disconnect the display flex cable: step 7, image 2 of 2
    • Use a spudger to disconnect the display flex cable.
  8. Core Assembly Removal, Disconnect the side buttons: step 8, image 1 of 2 Core Assembly Removal, Disconnect the side buttons: step 8, image 2 of 2
    • Use a spudger to disconnect the crown button flex cable.
  9. Core Assembly Removal, Unscrew the motherboard: step 9, image 1 of 1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  10. Core Assembly Removal, Remove the motherboard: step 10, image 1 of 3 Core Assembly Removal, Remove the motherboard: step 10, image 2 of 3 Core Assembly Removal, Remove the motherboard: step 10, image 3 of 3
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
    • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
  11. Core Assembly Removal, Lift the core assembly: step 11, image 1 of 3 Core Assembly Removal, Lift the core assembly: step 11, image 2 of 3 Core Assembly Removal, Lift the core assembly: step 11, image 3 of 3
    • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
    • Twist and tilt the spudger to lever the core assembly out of the metal housing.
  12. Core Assembly Removal, Release the core assembly: step 12, image 1 of 2 Core Assembly Removal, Release the core assembly: step 12, image 2 of 2
    • Thread the display flex cable through the opening in the core assembly.
  13. Core Assembly Removal, Remove the core assembly: step 13, image 1 of 1
    • Remove the core assembly.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
2 other people completed this guide.
Adriana Zwink
62,662 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,788 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 16
All Time: 1,283
