Corsair Katar DPI Sensor Replacement
  1. Corsair Katar DPI Sensor Replacement, Corsair Katar Disassembly: step 1, image 1 of 2 Corsair Katar DPI Sensor Replacement, Corsair Katar Disassembly: step 1, image 2 of 2
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
  2. Corsair Katar DPI Sensor Replacement: step 2, image 1 of 1
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
  3. Corsair Katar DPI Sensor Replacement: step 3, image 1 of 2 Corsair Katar DPI Sensor Replacement: step 3, image 2 of 2
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
  4. Corsair Katar DPI Sensor Replacement: step 4, image 1 of 1
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
  5. Corsair Katar DPI Sensor Replacement, DPI Sensor: step 5, image 1 of 2 Corsair Katar DPI Sensor Replacement, DPI Sensor: step 5, image 2 of 2
    • Use the JIS 0 screwdriver to remove the two 5mm screws holding the DPI sensor.
  6. Corsair Katar DPI Sensor Replacement: step 6, image 1 of 1
    • Lift the DPI sensor away from the mouse shell.
2 other people completed this guide.
Margaret Loughren
594 Reputation
5 Guides authored
UW Tacoma, Team S1-G3, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G3, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G3
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 429
