Corsair Katar Optical Sensor Replacement
  1. Corsair Katar Optical Sensor Replacement, Corsair Katar Disassembly: step 1, image 1 of 2 Corsair Katar Optical Sensor Replacement, Corsair Katar Disassembly: step 1, image 2 of 2
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
  2. Corsair Katar Optical Sensor Replacement: step 2, image 1 of 1
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
  3. Corsair Katar Optical Sensor Replacement: step 3, image 1 of 2 Corsair Katar Optical Sensor Replacement: step 3, image 2 of 2
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
  4. Corsair Katar Optical Sensor Replacement: step 4, image 1 of 1
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
  5. Corsair Katar Optical Sensor Replacement, Scroll Wheel: step 5, image 1 of 2 Corsair Katar Optical Sensor Replacement, Scroll Wheel: step 5, image 2 of 2
    • Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
  6. Corsair Katar Optical Sensor Replacement: step 6, image 1 of 1
    • Use the plastic opening tool to pry the white cable jack away from the motherboard.
    • Lift the motherboard away from the bottom of the mouse.
  7. Corsair Katar Optical Sensor Replacement: step 7, image 1 of 1
    • Push the scroll wheel to the right side of the motherboard as shown, then pull it away from the board to remove.
  8. Corsair Katar Optical Sensor Replacement, Optical Sensor: step 8, image 1 of 2 Corsair Katar Optical Sensor Replacement, Optical Sensor: step 8, image 2 of 2
    • Flip the motherboard over and remove the clear plastic cover from the bottom of the board.
  9. Corsair Katar Optical Sensor Replacement: step 9, image 1 of 2 Corsair Katar Optical Sensor Replacement: step 9, image 2 of 2
    • Desolder the 20 connecting pins to remove the optical sensor.
Margaret Loughren
594 Reputation
5 Guides authored
UW Tacoma, Team S1-G3, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G3, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G3
3 Members
13 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 14
All Time: 1,102
