Cowin E7 Extension Arm Replacement
  1. Cowin E7 Extension Arm Replacement, Extension Arm: step 1, image 1 of 2 Cowin E7 Extension Arm Replacement, Extension Arm: step 1, image 2 of 2
    • Remove four screws from the extension arm using a TR Torx 10 screwdriver.
  2. Cowin E7 Extension Arm Replacement: step 2, image 1 of 1
    • Pull up on the metal clamp.
    • Squeeze the pins on the top and bottom of the side you are trying to remove.
    • This will allow the extension bracket to easily slide out of the metal clamp.
  3. Cowin E7 Extension Arm Replacement: step 3, image 1 of 1
    • Replace the damaged extension bracket with a new one.
    • To insert the new bracket, remember to squeeze the pins on the side that inserts into the metal clamp.
Jacob Burrer
439 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 30
All Time: 796
