Cr-48 Chromebook SSD Replacement
  1. Cr-48 Chromebook SSD Replacement, Battery: step 1, image 1 of 3 Cr-48 Chromebook SSD Replacement, Battery: step 1, image 2 of 3 Cr-48 Chromebook SSD Replacement, Battery: step 1, image 3 of 3
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: step 2, image 1 of 2 Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Cr-48 Chromebook SSD Replacement, Remove Screws: step 3, image 1 of 3 Cr-48 Chromebook SSD Replacement, Remove Screws: step 3, image 2 of 3 Cr-48 Chromebook SSD Replacement, Remove Screws: step 3, image 3 of 3
    • Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
    • Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
  4. Cr-48 Chromebook SSD Replacement: step 4, image 1 of 3 Cr-48 Chromebook SSD Replacement: step 4, image 2 of 3 Cr-48 Chromebook SSD Replacement: step 4, image 3 of 3
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: step 5, image 1 of 3 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: step 5, image 2 of 3 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: step 5, image 3 of 3
    • Find the SSD located on a corner of the side directly opposite where the laptop screen and device body are connected.
    • Remove one black screw on the SSD using a PH #00 screwdriver.
    • Size ph#00, approximately 3 mm long.
    • Once unscrewed, the SSD will pop up from the device.
  6. Cr-48 Chromebook SSD Replacement, Remove SSD: step 6, image 1 of 2 Cr-48 Chromebook SSD Replacement, Remove SSD: step 6, image 2 of 2
    • Firmly grasp the SSD with two fingers slightly upwards and pull.
5 other people completed this guide.
Athar
365 Reputation
2 Guides authored
CSU Fullerton, Team 2-2, Bruce Fall 2014 Member of CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 53
All Time: 3,253
