Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank Replacement
  1. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement, Fuel Tank: step 1, image 1 of 2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement, Fuel Tank: step 1, image 2 of 2
    • Remove the fuel line from the fuel tank with pliers.
  2. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: step 2, image 1 of 2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: step 2, image 2 of 2
    • Take off the fuel cap and place a safe container under the fuel line.
    • Make sure to drain all of the fuel from the fuel tank into the container.
  3. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: step 3, image 1 of 2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: step 3, image 2 of 2
    • Remove the four support bolts on the top of the tank and motor with a crescent wrench or socket wrench.
  4. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: step 4, image 1 of 1
    • Lift the fuel tank off of the lower supporting brackets.
  5. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: step 5, image 1 of 1
    • Replace the cracked fuel tank and place the new one onto the lower supporting brackets.
  6. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: step 6, image 1 of 1
    • Screw in the top four supporting bracket bolts with a crescent wrench or socket wrench to hold the new fuel tank in place.
  7. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: step 7, image 1 of 1
    • Reconnect the fuel line and hose clamp.
  8. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: step 8, image 1 of 1
    • Fill the tank with fuel.
    • Check to make sure that the hose clamp is not leaking.
Megan Smith
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 2,010
