Craftsman Model 315.10721 Brush Replacement
  1. Craftsman Model 315.10721 Brush Replacement, Brush: step 1, image 1 of 2 Craftsman Model 315.10721 Brush Replacement, Brush: step 1, image 2 of 2
    • Using a flathead screwdriver, remove the brush caps on the outer casing of the saw near the motor.
  2. Craftsman Model 315.10721 Brush Replacement: step 2, image 1 of 1
    • Using a Phillips #00 screwdriver or a small diameter nail, carefully pull out the washer.
    • The washer is seurely held in place and may require force to remove
  3. Craftsman Model 315.10721 Brush Replacement: step 3, image 1 of 1
    • After the washers are removed, gently grab the old brushes and remove them from the motor.
    • When reassembling make sure the curvature of the brushes match curvature of the motor.
Riley Hilliker
557 Reputation
5 Guides authored
Cal Poly, Team 4-47, Amido Fall 2014 Member of Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 19
All Time: 1,432
