Craftsman Model 315.10721 Switch Replacement
  1. Craftsman Model 315.10721 Switch Replacement, Switch: step 1, image 1 of 1
    • Remove the two 1" Phillips screws using a #1 Phillips screwdriver.
    • Remove the three 1/2" Phillips screws using a #1 Phillips screwdriver.
    • Once the five screws are removed, lift the handle cover from the saw.
  2. Craftsman Model 315.10721 Switch Replacement: step 2, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the 1/2" silver screw that is securing the switch.
  3. Craftsman Model 315.10721 Switch Replacement: step 3, image 1 of 1
    • Using a Phillips #00 screwdriver or a small diameter screwdriver, gently insert it into the leads. When the screwdriver is inserted into the lead, it will release the wire.
    • The leads are where the black and white wires from the switch are plugged in.
    • Release both sets of the black and white wires and gently pull them from the leads.
    • To install the new switch, insert the wires of the new cord in the same way that they were removed.
Riley Hilliker
557 Reputation
5 Guides authored
Cal Poly, Team 4-47, Amido Fall 2014 Member of Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 24
All Time: 1,347
