Craig Electronics CMP773 Battery Replacement
  1. Craig Electronics CMP773 Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the two 3.2 mm PH000 screws near the charging port.
  2. Craig Electronics CMP773 Battery Replacement: step 2, image 1 of 1
    • Pry the back cover from the device along the bottom edge.
  3. Craig Electronics CMP773 Battery Replacement: step 3, image 1 of 1
    • Continue prying along the edge of the device until the back cover is free.
  4. Craig Electronics CMP773 Battery Replacement: step 4, image 1 of 1
    • Pry the battery free from the device using a plastic opening tool.
  5. Craig Electronics CMP773 Battery Replacement: step 5, image 1 of 1
    • Desolder the faulty battery wires.
  6. Craig Electronics CMP773 Battery Replacement: step 6, image 1 of 1
    • Solder the replacement battery wires to the circuit board.
  7. Craig Electronics CMP773 Battery Replacement: step 7, image 1 of 1
    • Apply adhesive between the replacement battery and the device before installation.
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced battery.
Jacob Hampton
145 Reputation
1 Guide authored
IUPUI, Team S1-G5, Harley Spring 2018 Member of IUPUI, Team S1-G5, Harley Spring 2018
IUPUI-HARLEY-S18S1G5
6 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 276
