Craig Electronics CMP773 Front and Rear Camera Replacement
  1. Craig Electronics CMP773 Front and Rear Camera Replacement, Front and Rear Camera: step 1, image 1 of 2 Craig Electronics CMP773 Front and Rear Camera Replacement, Front and Rear Camera: step 1, image 2 of 2
    • Remove the two Phillips #00 screws from the bottom of the screen.
  2. Craig Electronics CMP773 Front and Rear Camera Replacement: step 2, image 1 of 2 Craig Electronics CMP773 Front and Rear Camera Replacement: step 2, image 2 of 2
    • Insert a plastic opening tool underneath the screen.
    • Once the first tool is inserted, insert another opening tool along the same side of the tablet.
    • Pry them in opposite directions until the casing pops.
  3. Craig Electronics CMP773 Front and Rear Camera Replacement: step 3, image 1 of 2 Craig Electronics CMP773 Front and Rear Camera Replacement: step 3, image 2 of 2
    • Move the opening tool along the edge of the tablet to continue popping the casing loose.
    • Once the casing is about half loose, remove it by hand.
  4. Craig Electronics CMP773 Front and Rear Camera Replacement: step 4, image 1 of 2 Craig Electronics CMP773 Front and Rear Camera Replacement: step 4, image 2 of 2
    • Remove the tape from the power connection for the camera unit.
    • Unhinge the clamp on the camera power connection to expose the removable plug.
  5. Craig Electronics CMP773 Front and Rear Camera Replacement: step 5, image 1 of 1
    • Gently remove the power ribbon from the connector.
  6. Craig Electronics CMP773 Front and Rear Camera Replacement: step 6, image 1 of 2 Craig Electronics CMP773 Front and Rear Camera Replacement: step 6, image 2 of 2
    • Use the spudger to dislodge camera unit from the casing and remove it from the device.
Luke VanLangevelde
133 Reputation
1 Guide authored
IUPUI, Team S3-G4, Harley Fall 2019 Member of IUPUI, Team S3-G4, Harley Fall 2019
IUPUI-HARLEY-F19S3G4
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 92
