Craig Electronics CMP773 Screen Replacement
  1. Craig Electronics CMP773 Screen Replacement, Screen: step 1, image 1 of 2 Craig Electronics CMP773 Screen Replacement, Screen: step 1, image 2 of 2
    • Remove two screws on the charging port side of the tablet using the Phillips #00 screwdriver.
  2. Craig Electronics CMP773 Screen Replacement: step 2, image 1 of 3 Craig Electronics CMP773 Screen Replacement: step 2, image 2 of 3 Craig Electronics CMP773 Screen Replacement: step 2, image 3 of 3
    • Insert a plastic opening tool between the screen and the back of the tablet.
    • Insert another opening tool along the same side of the tablet and pry them in opposite directions until the casing pops.
    • Once roughly half of the case has been unlatched, it can be removed by hand.
  3. Craig Electronics CMP773 Screen Replacement: step 3, image 1 of 2 Craig Electronics CMP773 Screen Replacement: step 3, image 2 of 2
    • Use the spudger to gently pry the camera from the casing.
  4. Craig Electronics CMP773 Screen Replacement: step 4, image 1 of 2 Craig Electronics CMP773 Screen Replacement: step 4, image 2 of 2
    • Using your finger, remove the clamp that connects the screen power rib to the motherboard.
    • Using needle nose pliers, remove the ribbon.
  5. Craig Electronics CMP773 Screen Replacement: step 5, image 1 of 3 Craig Electronics CMP773 Screen Replacement: step 5, image 2 of 3 Craig Electronics CMP773 Screen Replacement: step 5, image 3 of 3
    • Remove the second screen power connection from the motherboard using the same procedure as step 4.
  6. Craig Electronics CMP773 Screen Replacement: step 6, image 1 of 3 Craig Electronics CMP773 Screen Replacement: step 6, image 2 of 3 Craig Electronics CMP773 Screen Replacement: step 6, image 3 of 3
    • Remove four screws from the motherboard using the Phillips #00 screwdriver.
  7. Craig Electronics CMP773 Screen Replacement: step 7, image 1 of 2 Craig Electronics CMP773 Screen Replacement: step 7, image 2 of 2
    • Remove a single screw from the speaker using the Phillips #00 screwdriver.
    • Pry up on the locking tabs with the flat spudger.
  8. Craig Electronics CMP773 Screen Replacement: step 8, image 1 of 1
    • Using needle nose pliers, remove the ground wire from the casing.
  9. Craig Electronics CMP773 Screen Replacement: step 9, image 1 of 1
    • Using the plastic opening tool, remove the battery.
  10. Craig Electronics CMP773 Screen Replacement: step 10, image 1 of 2 Craig Electronics CMP773 Screen Replacement: step 10, image 2 of 2
    • With all screws and components removed, gently remove the motherboard from the casing.
  11. Craig Electronics CMP773 Screen Replacement: step 11, image 1 of 3 Craig Electronics CMP773 Screen Replacement: step 11, image 2 of 3 Craig Electronics CMP773 Screen Replacement: step 11, image 3 of 3
    • Insert the spudger in between the screen and case. Work your way around the outside of the screen.
  12. Craig Electronics CMP773 Screen Replacement: step 12, image 1 of 3 Craig Electronics CMP773 Screen Replacement: step 12, image 2 of 3 Craig Electronics CMP773 Screen Replacement: step 12, image 3 of 3
    • Grasp the exposed screen corner and gently separate the screen from the housing.
Justin mersch
205 Reputation
1 Guide authored
IUPUI, Team S3-G4, Harley Fall 2019 Member of IUPUI, Team S3-G4, Harley Fall 2019
IUPUI-HARLEY-F19S3G4
4 Members
3 Guides authored
One Comment
What kind of battery does this device specifically use
Kris Miller - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 212
