Craig Electronics CMP773 Volume/Power Control Button Replacement
  1. Craig Electronics CMP773 Volume/Power Control Button Replacement, Volume/Power Control Button: step 1, image 1 of 1
    • Remove the two 3.2 mm PH000 screws near the charging port.
  2. Craig Electronics CMP773 Volume/Power Control Button Replacement: step 2, image 1 of 1
    • Pry the back cover from the device along bottom edge.
  3. Craig Electronics CMP773 Volume/Power Control Button Replacement: step 3, image 1 of 1
    • Continue prying along each edge of the device until back cover is free.
  4. Craig Electronics CMP773 Volume/Power Control Button Replacement: step 4, image 1 of 1
    • On the back cover, find the location where the volume/power button is held.
    • The volume/power button is not held securely after back is removed so it may fall out of place while removing the back cover from the device.
  5. Craig Electronics CMP773 Volume/Power Control Button Replacement: step 5, image 1 of 2 Craig Electronics CMP773 Volume/Power Control Button Replacement: step 5, image 2 of 2
    • Remove the old button and replace it with the new one.
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced volume/power control button.
Jessie L Morris
171 Reputation
1 Guide authored
IUPUI, Team S1-G5, Harley Spring 2018 Member of IUPUI, Team S1-G5, Harley Spring 2018
IUPUI-HARLEY-S18S1G5
6 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 186
