Crayola Crayon Maker Light Bulb Removal and Replacement
  1. Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: step 1, image 1 of 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: step 1, image 2 of 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: step 1, image 3 of 3
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: step 2, image 1 of 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: step 2, image 2 of 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: step 2, image 3 of 3
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  3. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: step 3, image 1 of 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: step 3, image 2 of 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: step 3, image 3 of 3
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
Finish Line
Heidi Clarke
222 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 6,883
