Crayola Crayon Maker Sliding Lock Mechanism Replacement
  1. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: step 1, image 1 of 3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: step 1, image 2 of 3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: step 1, image 3 of 3
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: step 2, image 1 of 3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: step 2, image 2 of 3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: step 2, image 3 of 3
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  3. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: step 3, image 1 of 3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: step 3, image 2 of 3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: step 3, image 3 of 3
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
  4. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: step 4, image 1 of 3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: step 4, image 2 of 3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: step 4, image 3 of 3
    • Flip the crayon maker.
    • Remove six screws (2 cm in length) with a spanner.
    • Remove the green base plate and set it aside.
  5. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: step 5, image 1 of 3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: step 5, image 2 of 3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: step 5, image 3 of 3
    • Locate the clear plastic arm inside the control box.
  6. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Adjust/Replace the Plastic Arm: step 6, image 1 of 2 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Adjust/Replace the Plastic Arm: step 6, image 2 of 2
    • If necessary, unscrew the plastic arm with a Phillips #00 Precision screwdriver and readjust the arm until the desired position is reached.
    • If the plastic arm is broken, contact Crayola for replacement parts.
Heidi Clarke
222 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 786
