Creality Ender 3 Extruder Motor Assembly Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Creality Ender 3 Extruder Motor Assembly Replacement, extruder motor assembly: step 1, image 1 of 1
    • To start, unplug the cable from the power supply box.
  2. Creality Ender 3 Extruder Motor Assembly Replacement: step 2, image 1 of 2 Creality Ender 3 Extruder Motor Assembly Replacement: step 2, image 2 of 2
    • Remove the screw holding the spring in place.
    • Also, before going any further, remove the PFTE tubing from the assembly.
  3. Creality Ender 3 Extruder Motor Assembly Replacement: step 3, image 1 of 2 Creality Ender 3 Extruder Motor Assembly Replacement: step 3, image 2 of 2
    • Once the screw is removed, take out the spring and the small metal bracket inside.
    • Once you are done, recall how the spring and bracket are put together.
  4. Creality Ender 3 Extruder Motor Assembly Replacement: step 4, image 1 of 1
    • Now, remove the small brass gear by loosening the small screws.
    • Do not loosen the screws all the way.
This is a fairly easy repair, but if you need help, leave a comment on the guide.
Cameron Smith
400 Reputation
2 Guides authored
Colorado Fixers Member of Colorado Fixers
Community
1 Member
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 484
