Creative Zen V Plus Logic Board Replacement
  1. Creative Zen V Plus Logic Board Replacement, Prerequisite Only: step 1, image 1 of 1
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Logic Board Replacement: step 2, image 1 of 1
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Logic Board Replacement: step 3, image 1 of 1
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Logic Board Replacement: step 4, image 1 of 2 Creative Zen V Plus Logic Board Replacement: step 4, image 2 of 2
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Logic Board Replacement: step 5, image 1 of 1
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Logic Board Replacement: step 6, image 1 of 3 Creative Zen V Plus Logic Board Replacement: step 6, image 2 of 3 Creative Zen V Plus Logic Board Replacement: step 6, image 3 of 3
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Logic Board Replacement, Logic Board: step 7, image 1 of 1
    • Unplug the logic board from the battery. Replace the logic board with your new logic board and reassemble your device.
Joel Ng
242 Reputation
1 Guide authored
IUPUI, Team 2-5, Baechle Fall 2016 Member of IUPUI, Team 2-5, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G5
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 486
