Creative Zen Vision W Keypad Replacement
  1. Creative Zen Vision W Keypad Replacement, Front Cover: step 1, image 1 of 2 Creative Zen Vision W Keypad Replacement, Front Cover: step 1, image 2 of 2
    • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
  2. Creative Zen Vision W Keypad Replacement: step 2, image 1 of 3 Creative Zen Vision W Keypad Replacement: step 2, image 2 of 3 Creative Zen Vision W Keypad Replacement: step 2, image 3 of 3
    • Run the spudger along the cover and pry.
    • Do this gently to preserve the screen
    • The button pad may fall off when the cover is removed.
  3. Creative Zen Vision W Keypad Replacement, LCD Screen: step 3, image 1 of 3 Creative Zen Vision W Keypad Replacement, LCD Screen: step 3, image 2 of 3 Creative Zen Vision W Keypad Replacement, LCD Screen: step 3, image 3 of 3
    • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
    • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
  4. Creative Zen Vision W Keypad Replacement: step 4, image 1 of 1
    • Put the screen face down so you can see where the ribbon cables are attached.
    • Remove the red sticker that covers the ribbon cable connections.
  5. Creative Zen Vision W Keypad Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
  6. Creative Zen Vision W Keypad Replacement: step 6, image 1 of 3 Creative Zen Vision W Keypad Replacement: step 6, image 2 of 3 Creative Zen Vision W Keypad Replacement: step 6, image 3 of 3
    • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
    • Remove the screen from the device.
  7. Creative Zen Vision W Keypad Replacement, Keypad: step 7, image 1 of 1
    • Peel the orange sticker off of the motherboard.
  8. Creative Zen Vision W Keypad Replacement: step 8, image 1 of 2 Creative Zen Vision W Keypad Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Lift the keypad from the left side and use tweezers to slide it out to the left.
  9. Creative Zen Vision W Keypad Replacement: step 9, image 1 of 2 Creative Zen Vision W Keypad Replacement: step 9, image 2 of 2
    • Use a small flat head screw driver to slide the white tabs away from the ribbon cable connection.
    • Remove the ribbon cable from the keypad.
Tim Wilson
143 Reputation
6 Guides authored
Cal Poly, Team 17-2, Regan Spring 2013 Member of Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 427
