Creative Zen X-Fi LCD Screen Replacement
  1. Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: step 1, image 1 of 3 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: step 1, image 2 of 3 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: step 1, image 3 of 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Creative Zen X-Fi LCD Screen Replacement, Rubber Button Cover: step 2, image 1 of 1
    • The black rubber button pad can be removed by simply picking it up.
  3. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip Part 1: step 3, image 1 of 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip: step 4, image 1 of 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Creative Zen X-Fi LCD Screen Replacement, Access Midsection Plate: step 5, image 1 of 1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Creative Zen X-Fi LCD Screen Replacement, Unscrew below Button Chip: step 6, image 1 of 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Creative Zen X-Fi LCD Screen Replacement, Unscrew below LCD Screen: step 7, image 1 of 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: step 8, image 1 of 2 Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: step 8, image 2 of 2
    • Lift the right edge of the motherboard off the back case.
    • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
  9. Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: step 9, image 1 of 2 Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: step 9, image 2 of 2
    • Use two fingers to peel back the edge of the ribbon connector that is glued to the bottom of the LCD screen.
  10. Creative Zen X-Fi LCD Screen Replacement, Unlatch the LCD Screen: step 10, image 1 of 1
    • Using a plastic opening tool, unlock the ribbon connector by unlatching the black lever that pins it on the motherboard.
    • Once the black lever arm is open, pull the ribbon connector out to disconnect the LCD screen.
3 other people completed this guide.
Westley Courchene
3,410 Reputation
14 Guides authored
USF Tampa, Team 1-1, Remmell Fall 2015 Member of USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 1,546
