Creative Ziio 7" LCD Screen Replacement
  1. Creative Ziio 7" LCD Screen Replacement, Back Panel: step 1, image 1 of 3 Creative Ziio 7" LCD Screen Replacement, Back Panel: step 1, image 2 of 3 Creative Ziio 7" LCD Screen Replacement, Back Panel: step 1, image 3 of 3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" LCD Screen Replacement, LCD Screen: step 2, image 1 of 1
    • Remove the four 3mm Philips #00 screws around the large silver battery.
  3. Creative Ziio 7" LCD Screen Replacement: step 3, image 1 of 1
    • Remove the four 4mm Philips #00 screws on the edges of the circuit board.
  4. Creative Ziio 7" LCD Screen Replacement: step 4, image 1 of 3 Creative Ziio 7" LCD Screen Replacement: step 4, image 2 of 3 Creative Ziio 7" LCD Screen Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the ribbon cable from the exposed side of circuit board near the headphone jack.
    • Carefully lift up the circuit board on the detached side.
    • There is another ribbon cable attached to the underside of the circuit board.
    • Disconnect the second ribbon cable by pulling the end of the ribbon from its housing on the circuit board with tweezers.
    • The circuit board is extremely delicate. Move carefully and don't rush on this step!
  5. Creative Ziio 7" LCD Screen Replacement: step 5, image 1 of 1
    • On the opposite end of the device: Remove the ribbon cable in between the speakers at the end of the battery.
  6. Creative Ziio 7" LCD Screen Replacement: step 6, image 1 of 1
    • There are three additional 3mm Philips #00 screws underneath the circuit board that need to be removed.
    • Now, remove the battery and circuit board with the LCD attached and turn it over so the screen is facing upwards.
  7. Creative Ziio 7" LCD Screen Replacement: step 7, image 1 of 2 Creative Ziio 7" LCD Screen Replacement: step 7, image 2 of 2
    • Carefully pry the thin, metal frame from around the LCD screen.
    • The frame is extremely thin! Take your time when removing it to avoid bending or deforming it.
  8. Creative Ziio 7" LCD Screen Replacement: step 8, image 1 of 1
    • Carefully remove the black LCD screen.
2 other people completed this guide.
Kyle
120 Reputation
2 Guides authored
Cal Poly, Team 14-10, Maness Spring 2013 Member of Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Members
13 Guides authored
2 Guide Comments
Where can I buy Creative Ziio 7" LCD Scren?
CoolBlazer - Reply
i need LCD Creative Labs ZIIO 7 Inch Tablet, where i can buy?... please help me... thx before...
irawansandra -
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,522
