You're viewing a previously published version of this guide.  View latest version
Older Newer
Cricut Maker Top Door/ Lid Replacement
Devyn White
Devyn White and 3 other contributors
Last updated on March 25, 2024
10 - 20 minutes
Moderate
Introduction
Go to step 1
In the event that the door of your Cricut Maker won't stay closed because it's damaged, it could be time for a replacement. Follow this step-by-step guide to change the lid on your own.
First make sure the connecting magnets are clear of debris, which may be preventing them from closing. If there are any obstructions, clear these away and the magnets should stick once again. However, in the event that there is no obstruction, perform a magnetic test on the lid magnet to the front door to determine if you need to replace the lid.
In step one, you must pry glue from plastic, so be gentle to avoid breaking or damaging the lid further.
Tools
Show more…
  1. Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: step 1, image 1 of 3 Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: step 1, image 2 of 3 Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: step 1, image 3 of 3
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
  2. Cricut Maker Top Door/ Lid Replacement: step 2, image 1 of 2 Cricut Maker Top Door/ Lid Replacement: step 2, image 2 of 2
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
  3. Cricut Maker Top Door/ Lid Replacement: step 3, image 1 of 3 Cricut Maker Top Door/ Lid Replacement: step 3, image 2 of 3 Cricut Maker Top Door/ Lid Replacement: step 3, image 3 of 3
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
  4. Cricut Maker Top Door/ Lid Replacement: step 4, image 1 of 1
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
Devyn White
1,113 Reputation
5 Guides authored
Past 24 Hours: 16
Past 7 Days: 41
Past 30 Days: 141
All Time: 3,558
