Crosley CR42 Power Cable Replacement
  1. Crosley CR42 Power Cable Replacement, Power Cable: step 1, image 1 of 2 Crosley CR42 Power Cable Replacement, Power Cable: step 1, image 2 of 2
    • Turn the device around until you are looking at the line-out port.
    • With a cordless drill or Phillips #0 screwdriver, remove the ten 12-mm screws.
  2. Crosley CR42 Power Cable Replacement: step 2, image 1 of 3 Crosley CR42 Power Cable Replacement: step 2, image 2 of 3 Crosley CR42 Power Cable Replacement: step 2, image 3 of 3
    • Gently remove the back of the device. It should be connected by two wires.
  3. Crosley CR42 Power Cable Replacement: step 3, image 1 of 3 Crosley CR42 Power Cable Replacement: step 3, image 2 of 3 Crosley CR42 Power Cable Replacement: step 3, image 3 of 3
    • Gently remove both wires.
    • After de-threading the antenna wire, remove the back of the device and set it aside.
  4. Crosley CR42 Power Cable Replacement: step 4, image 1 of 3 Crosley CR42 Power Cable Replacement: step 4, image 2 of 3 Crosley CR42 Power Cable Replacement: step 4, image 3 of 3
    • Locate where the power cable connects to the device.
    • Pick up the device and locate the screw holding the small black peg to the device. Unscrew it and set the screw aside.
  5. Crosley CR42 Power Cable Replacement: step 5, image 1 of 3 Crosley CR42 Power Cable Replacement: step 5, image 2 of 3 Crosley CR42 Power Cable Replacement: step 5, image 3 of 3
    • With the pliers, remove the wire connectors. You may need to be forceful
    • It is wise to attach a marking in order to recognize how the wires should be reattached.
  6. Crosley CR42 Power Cable Replacement: step 6, image 1 of 3 Crosley CR42 Power Cable Replacement: step 6, image 2 of 3 Crosley CR42 Power Cable Replacement: step 6, image 3 of 3
    • Pull apart both groups of wires.
    • After getting your replacement power cord, make sure you recognize how the wires should reattach.
  7. Crosley CR42 Power Cable Replacement: step 7, image 1 of 3 Crosley CR42 Power Cable Replacement: step 7, image 2 of 3 Crosley CR42 Power Cable Replacement: step 7, image 3 of 3
    • Twist the connecting wires together.
    • Attach the twist-on wire connectors to the exposed wires.
Eric Dybsetter
175 Reputation
1 Guide authored
Cal Poly, Team 1-38, Maness Winter 2014 Member of Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 46
All Time: 6,385
