Crosley CR704 Speaker Replacement
  1. Crosley CR704 Speaker Replacement, Speaker: step 1, image 1 of 1
    • Using your Philips head screwdriver, remove the 10 outer black screws from the back of the device.
  2. Crosley CR704 Speaker Replacement: step 2, image 1 of 1
    • Gently remove the back panel of the device being careful not to unplug any internal wires.
  3. Crosley CR704 Speaker Replacement: step 3, image 1 of 1
    • Using your Phillips head screwdriver, remove the 4 brass speaker screws.
    • Be careful to not remove the speaker housing screws, which surround the speaker screws.
  4. Crosley CR704 Speaker Replacement: step 4, image 1 of 1
    • Carefully pull the wires out of their connections from the back of the speaker.
    • Don't forget which wire goes with which connection!
To reassemble, follow these instructions in reverse order. Then test by playing a tune. We suggest "Live at the Apollo" by James Brown.
MarkAnthony
772 Reputation
5 Guides authored
One Comment
I've got this but the music plays super quietly on the records I'm not able to turn up the sound would this be the solution?
ninjadaniel66 - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 2,882
