Crosley CR8005A Volume Knob Replacement
  1. Crosley CR8005A Volume Knob Replacement, Volume Knob: step 1, image 1 of 1
    • Identify the volume knob.
    • It is in the bottom-right corner of the turntable, just under the power light.
  2. Crosley CR8005A Volume Knob Replacement: step 2, image 1 of 2 Crosley CR8005A Volume Knob Replacement: step 2, image 2 of 2
    • Make sure that the power is off.
    • Turn the volume knob counterclockwise as far as possible.
    • Unplug the power cord.
    • The power light should be off. If the light is glowing red, wait until the light goes out.
  3. Crosley CR8005A Volume Knob Replacement: step 3, image 1 of 1
    • Slip the plastic opening tool between the knob and the turntable.
    • In place of an opening tool, a spudger will also work.
  4. Crosley CR8005A Volume Knob Replacement: step 4, image 1 of 2 Crosley CR8005A Volume Knob Replacement: step 4, image 2 of 2
    • Use the opening tool to pry open the knob.
    • To prevent the knob from flying off, you can keep one hand lightly on top of the knob for security. There may be an audible click as the knob comes off.
  5. Crosley CR8005A Volume Knob Replacement: step 5, image 1 of 1
    • The knob should now be free to inspect, customize, or replace.
To put the knob back on, push the knob directly down onto its peg.
Michael Doan
204 Reputation
1 Guide authored
2 Comments
Hi, how to change the actual know (not the plastic cover)?
As mine is faulty and I could use some help please haha
Lucas Robin - Reply
Digi-key part # similar to PTD908-1215K-B203-ND.
Scott Whitehill - Reply
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 40
All Time: 1,961
