Cruiser Bike Rear Wheel Replacement
  1. Cruiser Bike Rear Wheel Replacement, Rear Wheel: step 1, image 1 of 1
    • Flip your bike so the seat and handlebars are on the ground.
    • This will make it easier to access tire.
  2. Cruiser Bike Rear Wheel Replacement: step 2, image 1 of 1
    • Slip the chain onto the crank and rear cog. Then insert wheel into rear drop-outs.
    • Make sure that the chain is on the correct side of the wheel.
    • Handle the chain carefully to ensure a successful tire replacement.
  3. Cruiser Bike Rear Wheel Replacement: step 3, image 1 of 1
    • Tighten brake strap using screwdriver and 10 mm socket wrench.
    • Hold the nut on the inside (near the spokes) with wrench as you tighten the screw with the screwdriver.
    • You will know the socket wrench is has finished tightening when you feel resistance.
  4. Cruiser Bike Rear Wheel Replacement: step 4, image 1 of 1
    • Center the wheel and pull back to tighten the chain.
    • If the bike wheel is unusable use tire levers to remove tire.
  5. Cruiser Bike Rear Wheel Replacement: step 5, image 1 of 1
    • With the wheel pulled back, tighten the two axle nuts using the 15 mm socket wrench.
    • Tighten the non-drive side (side without the chain) first.
    • The wheel will angle as you tighten. Keep it centered with your hand as you finish tightening both axle nuts.
    • Use a tire pump to make sure the tire is full of air and ready to ride.
2 other people completed this guide.
Erin Heimburge
36 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 28
All Time: 11,650
